Simple question really...
When fitting a rear sway bar to a FB/EK im guessing you use the sway bar that matches the diff correct? ie. HR Diff you would use a Rear Sway bar to suit a HR?
Nathan
Rear Sway Bar
Rear Sway Bar
Foundation Member
Foundation Member
Re: Rear Sway Bar
KMAC used this logic when supplying me with a sway bar - LC torana length diff in FB Holden = they sent a LC torana swaybar.
Needless to say it was far from fitting.
When I contacted them and asked to exchange it they were very rude and refused to admit their mistake
Re: Rear Sway Bar
well my new thought would be in the case of a HR diff being fitted... there's not a lot of difference in the Banjo's so one to suit and FB would be better due to all the mounting brackets etc...
both arguments make sense...
Nathan
Nathan
Foundation Member
Foundation Member
Re: Rear Sway Bar
Yep get one suited to fb and you will be sweet. I think it is the leaf spring position which made the torana not fit so you will be fine with HR diff in your FB.
Re: Rear Sway Bar
went through this recently, running volvo diff, whiteline swaybar for FBEK fits fine.....
