Small Block for EK Wagon
Doc Bob
- State: WA
Re: Small Block for EK Wagon
Good to see all them shiny bits finally coming together Gaz......looking
'36 Chev Pick-up
'40 Chev Coupe Ute
'62 EK Wagon
'63 EH Roadster
'68 F#*d Fairlane
'76 LX SS Hatch
'36 Chev Pick-up
'40 Chev Coupe Ute
'62 EK Wagon
'63 EH Roadster
'68 F#*d Fairlane
'76 LX SS Hatch
Looking good Gaz, i wish my motor was painted grey!!!
Then i could say it had a grey motor...lol
will catch up for a look one day.
cheers
Dave
cheers
Dave
- WesternWagon
- State: WA
Finally got the remaining undercarriage rust repairs complete. ( now that the missus shed in complete)
The wagon is off the rotisserie for the time being.
Front clip complete just some welding once its back on the car and smooth of the inner guard cuts.
Stared on the brake pedal, all fitted up just some slight bending required to clear the column, a tidy up and then a Lokar pedal.
Bloody Hey fever has slowed things up over the last few days, 4 weeks of next break with plenty of wagon time planned (after I pick up the pumped up grey motor for the ute, from Bob at Serpie)
Gazza
Gazza
Member : Holden Car Club WA.
:ASRF Member
:ASRF Member
- Contact:
Just reread from Page 1. Coming along nicely Gaz. The white tape on the C pillar - are you heading towards a chop?
Stewart
Stewart
- WesternWagon
- State: WA
Did look at a chop Stewart, but its not going to happen. the tape is there to hold the doore shut on the rotisserie
Will remove the doors or use cable ties next time as the tape broke denting on of the doors
Gazza
Gazza
:ASRF Member
:ASRF Member
- WesternWagon
- State: WA
Front clip back on, a bit of tidy up on the inner guard cuts and some welding on the sub frame.
Sorted the pedal ox bent pedal, collapsible column, have a universal push rod for the booster is about 20 mm to long, bit more chopping in the morning and then on with the X member. Steering at last
Anyone have any simple suggestions to tidy up the column penetration
Gazza
Gazza
:ASRF Member
:ASRF Member
- WesternWagon
- State: WA
Trial fit up of the small block and Trans today, fits well, trans has heaps of room, need to modify the CRS trans support
Billet sump has to go (fouls the X member), looks like a electric fuel pump also as the mech one fouls on the lip, booster has heaps of room, steering is tight.
Now that the clip is on the inner guard cuts are not quite right, not sure if the alloy heads are are different angle to the cast ones ?? They are now closer to the engine block. The ADS tail shaft I have is 1/2 an inch to long (bugga) and will need shortening.
Diff has 31 spline Billet axles 3.08 for general use & 4.1's when it needs to go fast.
Coan trans is good for 600 HP with a 2800 stall.
As per Harvs advice quote="Harv"]Guessing the front end kit is the CRS (Hadfield) modified HR cross member? If so, normal SBC pressed-tin sump fits (at least my 1960 327 one did). Heaps of room around sump, but need to modify the drivers side firewall so that the cylinder head fits (make a 15mm indent with a BFH
).[/quote] I will probably just cut the lip off and modify the corner.
Some steel to modify the trans member on Moday, geeting close to paint time, cant wait.
Gazza
Gazza
:ASRF Member
:ASRF Member
when we've done holden V8's you massage the left side firewall the guy that does my fab work makes some cuts to push it back then puts the lip back so as it looks as if factory
I had the issue on the passenger side firewall, prob cause mine is a Holden V8 and used the Pat Gardiner front end
To overcome it we cut a piece out and plated it.
Gazza,
. I ended up going a Holley Red, mounted under the driver's side back seat floor (it tucked up out of the way nicely in amongst the crossmembers). Noisy as buggery though...hoping some carpet/dynamat/underlay quietens it down a bit (either that or the exhaust drowns it out
). Carter fuel pumps are apparently quieter than the Holleys (couldn't be any bloody louder). Think seriously about a fuel pump cutout switch (no ignition pulse or no oil pressure = no fuel pump power) - Peel Instruments make a nice unit that hides well up under the dash and is simple to wire in (if I can understand it, anyone can
Between you and Fingers, I'm starting to get the itch to get the wagon dragged back down to Sydney and finished
Harv.
Yep, SBC mech fuel pump foesn't like that front subframe lip at all. You could (almost) massage the lip and get the mech pump to fit, but you would need to pull the motor to change the fuel pumplooks like a electric fuel pump also as the mech one fouls on the lip, booster has heaps of room, steering is tight.
Harv.
- WesternWagon
- State: WA
Cheers Scoob
Nice work lookin good, mine is in a shit of a spot just on the corner of the steering column penetration.
I will make up and do similar to your passenger side, thanks for the pick.
:ASRF Member
:ASRF Member
- WesternWagon
- State: WA
Thanks Harv
Ya right about the Holley blue when I bought the warm grey of B ob it had a blue Holley and reg supplying the twins, you could hear it over the motor
The mechanic installing the NOS on my LJ recommended a Carter rotary vien, I have ordered a new stainless fuel tank with a 3/8 outlet for the wagon so should work out fine.
I spoke to Jonathan at Peel elects and we have an outlet over here for the safety switch part no CP-30 sounds like a good idea.
Well better go modify another piece of my CRS kit
so I can get this wagon ready or paint.
:ASRF Member
:ASRF Member
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>Harv wrote:Gazza,
Yep, SBC mech fuel pump foesn't like that front subframe lip at all.looks like a electric fuel pump also as the mech one fouls on the lip, booster has heaps of room, steering is tight.
Harv.
Yep my mechanical fuel pump wont fit either..... gotta go for aa electric pump too ....Do youse guys think the standard FB fuel line would keep up to the supply to 400 or 500 neddies.......Hey Gazz ...got any more photos on progress .....your experiences are helping me over here as well ..... check ya PMs mate ......
Fingers 0409253202 ............email ...........billsmith1@optusnet.com.au
barry grant fuel pumps are noisy mothers fichers as well
if any one comes up with a quite 1 im in
Fingers,
I reckon the standard FB/EK fuel lines are probably going to starve a V8 - undersized, often full of crap and bends/kinks/splits.... You can always check with a fuel pressure gauge with the vehicle under noise, but I'd reccomend some new 3/8" line.
Harv.
Harv.
