blue 202 wont start when hot
slimboy66
Post by slimboy66 »
my search in the engine section is fruitless at this stage. does anyone have any idea why i would be having trouble starting the car after the engine is warm. cold starts no worries . i'm sitting for 20 mins after getting fuel waiting for it to cool down then it will start. cheers
Re: blue 202 wont start when hot
more info please - what setup do you have ? Will it wind over and not fire or doesn't it wind over ?
slimboy66
Post by slimboy66 »
carb is a 350 stock motor water temp is normal oil pressure is fine the starter motor seems slow but it will start no probs cold. if that helps
fingers
Post by fingers »
Does the starter turn the motor over at a reasonable speed when hot .........Fingers
slimboy66
Post by slimboy66 »
it seems the same hot or cold so maybe the starters on the way out
It could be your extractors heating your starter motor.
Test by sheilding the starter with insulation of some type,
run the car as normal, see if hot starting improves.
This is not the fix, just an experiment to find the problem.
or
It could be vapor lock, your fuel line from the pump to the carbs is getting to hot.
Replace it, or shield it with rubber fuel line, or/and, move it away from the head.
Dont do both of these at the same time, you wont know which one worked (if at all).
Try one, then the other.
Jeff
Oh, hot or cold eh'
Swap in a new starter :wink:
slimboy66
Post by slimboy66 »
the starter motor seems the same hot or cold but only struggles starting hot
fingers
Post by fingers »
what thommo said and make sure ya got a heat shield .......Fingers :thumbsup: :thumbsup:
