vk 5 speed onto 161 for the rat
ek rat
Post by ek rat »
hey fellas ,i looked through the driveline section for some vk 5 speed advice but did not find much. i know celica is the bomb but i have no money and am looking for the cheepskate way out of this. otherwise the car will end up auto. :thumbsdown: has anyone out there done it? even if you jot down what you think you know about it might help me out before going to pick n payless . all i gathered was the clutch is cable and may need some mods there. any help would be appreciated.cheers
stinky
Re: vk 5 speed onto 161 for the rat
Post by stinky »
Have a look at the box and bell housing to see if there is a provision for a slave cylinder, or find out what other cars the box was fitted to and see if they came with hydraulic clutches. I think it would be easier to convert the box to hydraulic than the car to cable.
Shifter position might be a problem if you are running a bench seat.
