manual pedal box to auto
matches
Post by matches »
hi,
i'm changing my ek from manual (aussie 4 speed) to a trimatic. what do i need to do to the pedal box to change it to an auto? i know i need to lose one pedal (i got in efore the smartie's did :-P :ewink: ) do i need an actual ek auto brake pedal or is there something else i can use?
cheers, luke.
Re: manual pedal box to auto
You got the first bit right :mrgreen:
Then find an HK-T-G pedal and cut of the pad end and do the same to the EK brake pedal. Weld on to suit! Job done.
Before
After
matches
Post by matches »
thanks DR, thought it'd be something like that, just thought i'd ask the experts :wink: :lol:
cheers, luke.
Experts!! Never been called that before... Been called many other things though :mrgreen:
I just used an auto pedal in place of the other one :wink: .
if you can live with the small pedal just use the one that's there :ewink: and the shonky way to get rid of the clutch pedal if you have carpet, the clutch pedal is on a spring so will stay to the floor if pushed there so push it to the floor and put the carpet over it :thumbsup:
