MildFB, customised FB wagon
Ed
Re: MildFB, customised FB wagon
Post by Ed »
lol mild custom body work.
FE/FC Holden Car Club of NSW
Rusty EK
Post by Rusty EK »
Might have to change your post now Harko , bit too much info about yourself , now the previous post has been cleaned up by the mods :lol: :D
Harko wrote:I love learning about Holdens and penis lengthening .
:? but then i read
Rusty EK wrote: Might have to change your post now Harko , bit too much info about yourself , now the previous post has been cleaned up by the mods :lol: :D
:lol: that explains it :)
the car will have some interesting door trims :wink: :shock:
MildFB
Post by MildFB »
Door trims....? Oh yes, it has just occoured to me that we will need to modify around the new bit to add a ridge so the trim can sit behind ( as per the rest of the door). Job in progress.
I was going to re skin the doors, but I have found out that RareSpares skins are not available for FB-EK??, so I have got myself a reasonable door that I will have to scalp and use the skin on the modified door, I wish I knew that before we started. :cry:
Oh yes, I will have to add a bit of length to it's penis as well :?:
cheers Graham
If in doubt..chop it.
http://www.mildfb.com
there is other guys that do skins they usually advertise on ebay although mick jagger from here wasn't happy with the fit of some rears he got, you'de think fronts would be hard to get wrong though not having the wheel arch
Harko
Post by Harko »
:oops: Sorry I thought Id typed that into the other forum Im a mem aaah I accidentally clicked aaaah it popped up on my screen :D
I love watching this build and Im interested to see how much length you add.
Im thinking like a reversed stinger VWs have :D
MildFB
Post by MildFB »
August update. Re-skining the doors were done, since the front doors were already modified with the chop, I had to get good second hand doors and "scalp" them. Not an easy job, but managed to get the LHF door finished this way. RHF door needed a 1/2 skin, I couldn't find one to fit, so I made my own, it came up OK I think.
PS if your looking for 1/2 panels. Craig from http://www.rustaproblem.com.au has FB-EK in stock
Also looking at ways to mount our Malloo radiator, we have a VZ frame welded to the Chrysler chassis, and figuring out the FB gravel pan. We will have an expanded metal grill under the bumper for the radiator protection. Also looking at adding roll pan to blend it in a bit...
I appreciate it all looks very different to what your used to, but when you shut the bonnet, it will look FB. :eugeek:
cheers, Graham.
Crazy man :crazy:
Keep at it Graham, I'm keen to see it done :wink:
browny
Post by browny »
I 2nd that :thumbsup:
Yeah,
This car will be very interesting indeed once finished. Good on you guys keep going.
Thommo wrote:Crazy man :crazy:
x3 :thumbsup:
MildFB
Post by MildFB »
Thanks for the support. Our Engineer has OK'ed the build so far. Very encouraging. :thumbsup:
MildFB
Post by MildFB »
I cant believe its been a whole years gone bye, just though I'd add something just in case you're thinking we have packed up shop. Its a slow process but we will get there... here we have made a fiberglass air dam mold and modified the bumper's amongst other things.
These Pesky bumpers are too much trouble to be attached to the front and rear of the car where they can get damaged. Its been quite a process beating them into shape then welding them together into a single piece, now done, its off to get chromed.. anyone have ideas on a good outfit in Melbourne?? Cheers.
minifb
Post by minifb »
Ed wrote::shock: you're not seriously going to leave the huge gap between bonnet and screen like that??? :shock:
:lol: :lol: :lol: :lol:
FB/EKForum member 123
Harko
Post by Harko »
What are you planning for around the rear of the bonnet to screen , Kinda similar to camaro's how theres a large area that hides the wipers and the screen is blacked out that low , but I think from memmory which is fading ,the dash runs up level with the bonnet top so vision isnt impaired
