I have a 60 FB special, grey motor, and was wondering which other engines if any can be bolted straight in. Anyways if not which engines would be the best to get, 179 hp, 186? 202?
Thanks!
Which engines if any bolt into FB's?
Re: Which engines if any bolt into FB's?
Many engines can be "bolted in after the required mods are made...
Seriously though only a grey will bolt in, the 179, 186, 202 will all require some work to fit, ie front ends, engine mounts radiator, brakes, gearbox, diff etc....
Do a search we have a few posts on engine swaps.
Have a look at the CRS website to get an idea of what you could need to do the swap
http://www.rodshop.com.au/holden/fe-ek.htm
yep... someday...
Thanks for the info and help guys, Which 6 engine would be the best preformance wise? and with go fast parts, also bored etc.
A later model V6 Commodore motor would out do most stockish older straight 6's.
a V6 will chew most hotty red 6's
especially a manual version, but if yor going to the trouble/expense of fitting a V6 you might aswell fit a V8
Keith Black hemi V8...
go a 179 bored 120 thou equalls a 192 then stroke it 2 a 234 using either a 202 crank i think or a 221 &*#@ crank if u in wa give bob campbell a ring hes a magican with red motors builds hard racing mtrsJarrod wrote:I have a 60 FB special, grey motor, and was wondering which other engines if any can be bolted straight in. Anyways if not which engines would be the best to get, 179 hp, 186? 202?
Thanks!
willie wrote:go a 179 bored 120 thou equalls a 192 then stroke it 2 a 234 using either a 202 crank i think or a 221 &*#@ crank if u in wa give bob campbell a ring hes a magican with red motors builds hard racing mtrsJarrod wrote:I have a 60 FB special, grey motor, and was wondering which other engines if any can be bolted straight in. Anyways if not which engines would be the best to get, 179 hp, 186? 202?
Thanks!
Brings a 186 up to 235 cubes. Not cheap as special pistons have to be used as well.
Masterstroke engineering used to do it in the '80's , probably others as well.
Problem now is finding a good 221 crank as the 221 engines weren't very plentifull in their day and are harder to find now.
