Got Teeth?..... Quick Update
I am getting pretty sick of bodywork at the moment so I decied to have a break and start the mock up of the grille....
I have used overiders from an FB, I still need a few more but you get the idea.
- Contact:
Hey Devilrod,
Any further progress on the EK?
Stewart
Stewart
Some progress but no pics, front gaurds have been a nightmare. But they were the right price. Basically nearly ready for paint, one gaurd to go, all the doors are ready, body is basically right to go. Got a cash flow problem at the moment though.
Will post some pics once she's all primed up....
- Contact:
thanks for the update. Sounds like you're nearly there. Hope you get some $$$'s coming through...
Devilrods Teeth
Devilrod,
How have you created your grille using overriders,
I take it they have to be modified slightly, little grind here, little weld there to get them sitting right, but what are they mounted to exactly?
Have you used the original Grille frame or a modified unit?
I like these grilles like yours, the matt black flamed Ute in the other gallery and Streetneats FC Kustom (Oldholden.com) and would like to attempt something similar if possible (Time consuming but not Money Consuming)
Any help or ideas, do's and don'ts would be appreciated (Devilrod or anyone else)
NoMAD
NoMAD
The grille was only mocked up using the original grille bars. I plan on mounting the over-riders using brackets which pick up the original grille mounting points and at the moment the over-riders are unmodified, in case I change the grille later.
Devilrods Teeth
yeah that was what I was thinking, if I decided to give it a go I was going to get a bunch of over-riders, cut-out the plate/bracket already inside for the bumper, and weld in one running vertically and pic up the bolt holes on the grille frame in case I don’t like it, that would I could change back to original!, I wasn't sure whether or not I would cut a notch out of the top of the over-riders, depending how I want them to sit!
NoMAD
NoMAD
Over-Rider Size
I hadn't actuall tried to hunt them down yet, but thanks thats probably a good thing to know! i wasn't aware there was a size difference. i think i know a wreckers somewhere that has a few EK's or FB's rusting away that might be good for a few.
Thanks for that, i'll let you know how it turns out (When i get around to it eventually)
NoMAD
NoMAD
