Just done a swap with my eldest son.
I gave him my unregistered 1971 triumph Bonneville bike .. in exchange for a HR sedan rego to september.disk brake front. 3:08 'diff ( guess where the diff is heading
It has a genuine 186s motor with headers and dual,throat carb etc.( may well end up in the FB Van too.... oops i gave ya the answewr to question one..
It has a "miss"in it .
I have replaced the plugs.. leads... checked rocker adjustment ..dizzy cap for cracks or shorting...swapped the dizzy and leads out of the panno for a trial.....done a compression test with all pots returning around 175PSI.
I can drop either No:5 or No: 6 plug lead off and it makes no difference to the idle
Begining to think it has a head gasket leak between 5 and 6.... but cant explain the good compression in those two pots.
They should be down on squish if that was the case.
Gunna whip the head off it next weekend and have a looksee...
Which brings me to the title of this topic...
I have a couple of stock 186 and 179 heads kicking around the shed. Is there anything special about a 186 Head??
Bigger ports???? larger valves... anything at all??
Obviuosly if its just a gasket i can replace it . need to have a good look at the head first though.
Its over to you guys. Your thoughts
A: why it is missing
B: 186S head differences to a stocker.???
Yours in anticpation
Reddo
