Torana steering - which rack?
steved57
Post by steved57 »
Hi guys
Does anyone know if Torana front mounted steering racks from LC to UC are the same and, if not, which is the best model to use on a HR front end?
Cheers, Steve
FCOV6
Re: Torana steering - which rack?
Post by FCOV6 »
steved57 wrote:Hi guys
Cheers, Steve
The LH was the rack they used for most of the conversion around including CRS, i'm not sure if LC/LJ are same length but i'd guess they would have a slighly narrower track the LH-UC.
Post by mrs ratbox »
i've used both and i think the LC/LJ rack was better but we had to make extensions from the rack end to the tie rod end
DOLLER
Post by DOLLER »
Hey guys sorry to hijack this thread but I thought one of youse would know the answer (ratbox).
How should these torana racks be greased/lubed??? Would I take off the two "plates" and grease with a heavy type of grease like axel grease??
don't know never had to do it
FCOV6
Post by FCOV6 »
DOLLER wrote:Hey guys sorry to hijack this thread but I thought one of youse would know the answer (ratbox).
That plus remove the boots and wind in/out while greasing i guess ?
DOLLER
Post by DOLLER »
Yeah gotta put new boots on so i'll do that too.
A bit hard to explain, but what is the little phillips head screw in the cast section for?? Oil hole?
A Torana forum might be the place to ask.
steved57
Post by steved57 »
Thanks guys. Looks like either will do the trick.
Cheers, Steve :)
the rocket
Post by the rocket »
hi does anyone have any pics with a uc lj rack installed ( mrs ratbox?).
Does anyone know if the torana racks are different ie; v8 or 6?.
