EK morphs into pillarless Coupe .
Re: EK morphs into pillarless Coupe .
Which model Chev dash are you trying to fit ? I have a 59/60 dash to put in my 2 door
Harko
Post by Harko »
haha yep and Ill nut out repositioning the wipers while Im there
Post by mrs ratbox »
now you can put in a WB statesman dash :shock: (need that vomit emoticon again) :lol:
Ed
Post by Ed »
ratbox wrote:now you can put in a WB statesman dash :shock: (need that vomit emoticon again) :lol:
a VK dash :? :shock:
I'm sure you will work something out Harko :)
FE/FC Holden Car Club of NSW
EKfanPaul
Post by EKfanPaul »
Great to see a car like that being brought back to life. geez, some rust in her there, mate
Paul
Post by Mick Jagger »
Yeah , Star wars dash,..serious
kmawic
Harko
Post by Harko »
So today I pulled the same dash out of the 54 ,and looked at it and looked at the pieces and looked at it and considered the peices , Ive started welding the pieces back together :roll: so it seems its staying old school ,sorry Mick :wink:
Thanks Paul not much left now though .
Harko
Post by Harko »
Needed some metal to form the new dash top so I took the skin off a 90 corolla bonnet , fair $*#@ dinkum I threw it away , There should be laws against using that tin but instead with all our years of wisdom we now create cars with plastic panels that still weigh more than a 57 chevy.
The bonnet metal would have the strength of a sheet of thick cardboard :cry:
Sputzwagon
Post by Sputzwagon »
Harko wrote:Needed some metal to form the new dash top so I took the skin off a 90 corolla bonnet , fair $*#@ dinkum I threw it away , There should be laws against using that tin but instead with all our years of wisdom we now create cars with plastic panels that still weigh more than a 57 chevy.
I've got two more old HQ doors if you need the thicker steel, Harko. :shock: :lol:
Scotty.
Woofto Car Club Member No 2
Harko
Post by Harko »
Thanks Scotty much apreciated , Ive got an early Toyota crown bonnet here that will do the trick , nice thick maluable steel . :wink:
kiid61
Post by kiid61 »
Good to see your doing ya bit to deminish the pleague Harko..
Harko
Post by Harko »
well I like to participate :)
but now everybody knows you have part of a toyota in yor car :shock: :wink:
after fiddling around with my dash today they aren't made of very substantial material anyway, i'm not customising as such just some peanut put a guage cowl where the speaker grille was and brazed it to the dash and also cut the hole bigger :? as i'm not haveing a speaker there thought i might aswell just plate it, i'll use an old FB/EK door or bonnet :)
Harko
Post by Harko »
I measured it with the micrometre today and there was bugger all difference in the thickness but the rolla bonnet is like tin.
So in all honesty I could use the Holden Nova (corolla) material but then Ive got the toyota accelerator pedal already too.
Im actually not biased to the older rice burners theyre built well , better than any bommodore.
kiid61
Post by kiid61 »
Some corollas are kinda cool. I built a rotary ke20 not too long ago :oops:
