celica 5 speed
FB zombie
celica 5 speed
Post by FB zombie »
I was wondering if I put a Celica 5 speed into my FB would I have to loose the bench seat?
I currently have an M21 gear box with benchseat still intact
Any info would be appreciated
Post by mrs ratbox »
i'm pretty sure the shift is a little further back with the 5 speed but you can get a shift housing to put it in the same spot as the aussie
FB zombie
Post by FB zombie »
HI
TA for the reply and Info
So would I just have to extend linkages to where the shift housing sits?
is it an easy job or would I have to get a mechanic/transmission guy to fit?
Finny
State: QLD
Post by Finny »
I have a sedan with toyota 5 speed.
I would be struggling to get a bench set back in.
Not sure whats required as it was in the car when I got it.
Very nice to drive, 5 speed all syncro is very smooth and easy to drive.
Don't think I would try it myself, would also need a compliance plate and therefore an engineers approval, I'd get it done.
FB zombie
Post by FB zombie »
ta for the reply
I am going to give it a go!
as I have an M21 gear box(pain)
my wife wont drive it whe nyou change gears gets caught in between the gates in no gear
had it chimmed a few times
still unreliable
The toyoat Supra boxes can have the shifter housing reversed with some little modification and it moves the shifter forward, not sure if the Celica is the same.
blok
Post by blok »
FB zombie
Post by FB zombie »
man that is awsome!!!
ta for your help..looks like I can keep the bench seat..YES!!
Great link Blok , that is stickyworthy 8)
