FB ute Tailgate
Robo
FB ute Tailgate
Post by Robo »
Hi all
Would I be correct in thinking that the tailgate on a FB UTE has a slight curve both up and down as well as left and right ?
Cheers-Rob
Re: FB ute Tailgate
Pretty sure you are correct Rob definately the skin does
Robo
Re: FB ute Tailgate
Post by Robo »
Cheers Neil
My tailgate is beaten up pretty well
Re: FB ute Tailgate
Hi Rob hard to find a good tailgate now days you can buy skins but unless you have a frame, or bones I call it, then it does become very hard, I had ended up with 3 before I was lucky enough to grad a good one on ebay cost me $500 and still needed work.
Good luck
Robo
Re: FB ute Tailgate
Post by Robo »
My inner skin is in extremly poor condition as well. Am going to have a crack at making both inner and outer , will see how it pans out
Cheers- Rob
Re: FB ute Tailgate
Good luck Robo I'm sure there are plenty on here that would love to see photos of your progress with it.
Re: FB ute Tailgate
G’day Robo,
I was just talking to new mate Mark from Hoppers Crossing who is doing an EK Van. He made a new skin from sheet. Only curved it top to bottom he said.
Re: FB ute Tailgate
Re: FB ute Tailgate
Not obvious in the first photo, but he has welded a length of 30mm angle to the top hat section brace, corner out. Welded sheet at the top, then bent over the angle, and fixed the bottom. The sides apparently sat perfectly on the frame.
Clay
Robo
Re: FB ute Tailgate
Post by Robo »
Cheers Clay.....that's a great help
ROB
