Buckskin FB panel van
Re: Buckskin FB panel van
I got sick of seeing no new posts over the weekend. This bit isn’t very good:
The kill....
Got a head like 40 miles of bad road ........
More blood and gore at the Willunga knackery. Anybody in need or original steering and brake parts let me know. There are no drums on the front but one or two on the rear. Outrigger is spoken for.
The subframe has some good bits and would be repairable if keen and able. It is a pre-export subframe in that, as Glen pointed out, there I no provision for a passenger side handbrake roller. He actually went to the trouble of smoothing his. Battery area and inner guards are pretty good by the looks. All must go.
Clay,
Are the brake shoes good enough for exchange? Cause if so, yes please.
(And did this van come with a motor?)
They should be okay for rebonding Rob. No motor, gearbox, tailshaft, interior, stone guard or chrome.
Howdy Clay
Is the horn ring & steering column up for grabs?
All yours Stephen.
Sway bar brackets please Clay ? Someone in the club was chasing some - can't remember who but I will send out an email if they are still available and make the connection.
I’ll have a look Blacky but may need them for my van.
Thanks Clay
If you can put them aside and we can work out what the damage is
I've been focussing on cutting this up so I can cart this load over to Bendigo for oz ek to collect.
Philwreck from the FC forum is taking this.
Driver side rear quarter is up for grabs.
There is a working delco wiper motor and a few sundry bits, bonnet hinges etc.
The subframe is pretty crusty. Ok for some inner guard cuts. Roof is ok on the outside at least. May use it yet.
Plenum and dash are pretty good but front floor and pillar bottom are shot.
Upper tailgate has rust but wouldn't be a hard fix.
That's about it. The doors are rusty but repairable or tops can be used. Bonnet is solid. Guards are poor.
Clay,
Wiper motor and switch, please.
Ok Rob
