Hi,
The play on the pedal was getting too much. And I had repaired it twice prior.
So got a rare spares one in.
Have a look at the side by side below
You can see the two spot welds that join the pivot to the pedal are such that the foot that bolts to the floor is not set square like the left one. Left as it it hit the kick panel.
Also in the below you can see the difference in the angle of the lever (and my previous repair)
Not sure if the new pedal is out of spec. (First reaction). Or my pedal is out of spec. Or both!
One way to overcome this:
I ended up separating the two spot welds from the pedal, aligning the pedal straight. Then i added a section (in red) both sides and bottom ( U shaped) welded in. How do you do that with a rubber backed pedal?
This added piece is to extend the load to which the stress can transfer. I don’t think the two spot welds so close to one end provides the strength as that’s how mine failed previously. Plus I’m running twins so likely a bit more stress than a single.
Second thing I did was grind the spot welds on the pivot (green arrow) and turn the linkage lever to align with the old pedal angle and re-weld.
Tested, aligns well doesn’t foul and linkage works to full throttle opening.
Key learning: check your replacement rare spares pedal against your old one before you fit it. Mine were chalk and cheese.
Black dog
Accelerator pedal
Accelerator pedal
Nostalgia isn’t what it used to be.
Re: Accelerator pedal
There has been a bit of discussion here about this over the last year or so , some seem to be spot on , others like yours are not within cooee
A bit of a quality control issue over in China methinks ............ not that unusual
Never had to use a repro one. Original on the ute is like new, well almost. Either was low mileage or always held flat.
Re-do the welds joining the lever to the shaft - my rares one failed there before it left the spray shop - welds had zero penetration - i pointed it out to Dave at Rares and he was addressing it but the one i got in replacement a few months later was no better
Hi FJWally,
Thanks
I read your post prior on that as a warning and checked the shaft welds very closely. Surprising they were ok
Just the other attachment points!
Blackdog
Thanks
Blackdog
