Can someone swap my accelerator for me?
*edit*
hey all if anyone is willing to help me out this weekend and swap my accelerator over for me that would be awesome.. please PM me if you can help!
hi all have had a browse thru the topics and it appears that HEMI guy reckons the L300 accelerator cable is a straight swap...
can anyone confirm this?
if so, what model should i get?
gday folks
as promised heres the cable setup for my EK, its an relatively easy swap over & replaces the old mechanical setup
it also tidys up the firewall, as it allows you to delete the entire throttle linkage/brackets etc - but still uses the standard accelerator pedal
....which reminds me i must remove those brackets
*the cable used is off of a mitsi L300 express van 1980 something*
which is quite a long cable, and can be shortened considerably
the cable only cost about $5-$10, so why not grab a spare while your there
i guess a good starting point would be to remove the mechanical linkages etc
then youll need to attach the cable, to the acc pedal lever
you could use a pin, and split/cotter pin to attach the cable - but as you can see below...a small nut & bolt would suffice (maybe zinc/nickel plated type would suit the location)
then youll need to drill a hole in the floor/base of firewall, just above the acc pedal lever - to run the cable through
and a couple more holes, to attatch the cable guide also - see below
as you can see in the next pic, you run the cable inside the cabin (shown here with carpet pulled back)
and out of a hole in the firewall, the same hole as the choke cable runs through
*i would also recommend sealing around cable with silicone etc* for obvious reasons
the next pic shows the carpet back in its place - nice & neat
& finally attach the cable to the carby(application may vary, depending on carby), & youll also need some sort of outer cable holder - the same as a choke cable setup...see below
the final step is the fitment of a return spring, the cable setup will give you a lighter feeling pedal anyway - but can be counteracted somewhat with a stronger tension spring (youll have to play around with springs to find a "feel" that suits you)
also i fixed a plate on the top of the battery tray, with a hole in the top for the other end of the return spring - again see above
to finish up there will be some adjustment of the cable to ensure your getting maximum throttle etc
there was a chap that had a problem getting full throttle with this setup, to fix the problem he extended the accelerator pedal lever
i havnt had a problem with it since it was fitted over 2 years ago
good luck with it, if you choose to go down this path
you can rest assured, it is tried & proven
ps: heres a couple of sites that may help locate those carby/linkage tid bits you may need
thanks to stewart for posting those up
http://www.redlineauto.com.au
http://www.speco.com.au/acccarbfit.html
regards ray
regards ray
INVEST IN PRECIOUS METAL
Very nice post, Ray.
Pix and just enough text to leave no doubt........... well done.
Don't throw those old linkages away - those wanting to keep original may need them.
I have refurbed mine by Migging the holes and re-drilling them and building the rods and grinding them back to "just" fit.
- Contact:
I would BUT Junee isnt quiet Sydney. Sorry Im no helpbexterity wrote:so who feels like doing my swapover for me ?????![]()
anyone in sydney wanna come and help out a poor girl in distressplease let me know!!!
FB/EKForum member 123
Woofto Car Club Member No4
- BILLY BLACKARROW
- State: NSW
POST SUBJECT
Stingray/anyone ...this part isnt stock is it if it is I have lost mine
if not what is it off any idea's
I cant seem to post pic of what I'am talking about but it's the guide back into the cabin that the cable runs in.
